New to the Accord...:/
Old Jan 8, 2010 | 04:57 PM
DJVnavyCIVIC's Avatar
New User
Post New to the Accord...:/
Basically, i got a 98 4 door Honda Accord yesterday, runs pretty good 150,000 miles, im pretty sure it's the 2.3CL motor? But wut does that mean anyways, im sure it's F-series, new to it...Use to mess wit B-16 and 18's, now im un the Accord game, someone please help get me some feed back on info where i can find out more stuff about my new Honda, thanks.
Old Jan 8, 2010 | 06:43 PM
nus_dogg's Avatar
Default Re: New to the Accord...:/
Its a F23A1 2.3L engine. It can be a F23A4 if yours says ULEV with Green color around it on the valve cover.
Specifications
Bore × Stroke: 86.0 × 97.0 mm
Displacement: 2254 cc
Valve Configuration: SOHC, 16 valves, VTEC
Compression ratio: 9.3:1
Max power: 150 hp (112 kW) @ 5700 rpm
Max torque: 152 ft·lbf (205 N m) @ 4900 rpm
Some of the Acura CL also comes with this engine. Others have the 2.2L version depending on the trim.
Old Jan 8, 2010 | 08:15 PM
Atreidies's Avatar
Quote removed by Moderator
I'm a member there, and I do like the fact that it is a specialized forum, but I can only read so many "Check out my H.I.D./ lip kit/ new wheels" threads.
DJ - Use the search function and go to town. You can find just about everything you need there. And change you user name!!
Old Jan 8, 2010 | 08:18 PM
Atreidies's Avatar
Originally Posted by DJVnavyACCORD
Fixed
Tonyneedshelp
Mar 7, 2015 07:12 AM
matrix9_11
Mar 31, 2012 01:56 PM
f.e
Jan 10, 2010 03:55 AM
-isaac-
Apr 5, 2006 05:58 AM
suasa
Jul 1, 2005 07:17 AM
