What does this green light mean in my cluster?
In my 95 Del Sol cluster I have a little mini picture of a car on the left side and on that car its split up into sections with lights for each section to tell you things like your door is open or trunk is open or anything else.
Lately im getting a green light lighting up which appears to be where the gas tank is but ive checked the tank and the cap/door is closed what else could the light be or what else would cause that light to light up?
On a side note I also got the code 43(Fuel supply system) when I checked why my check engine light comes on randomly.
If the green light isnt about the gas tank then what is it and if it is about the gas tank what could be the problem?
Taking a wild guess here, but the gas cap might have gone bad. Bad, meaning it isn't holding pressure any more, which should set off a CEL. Could also explain why the car thinks the cap isn't there (wild guess on the green light part).
My DC2 threw a couple of different codes when the gas cap went bad, but all of them fuel system related. Before that happened, I didn't know a gas cap could go bad...
Wow thanks for the replies I never really payed attention to when it exactly came on it seemed random lol...
How about the code 43? What all could cause that and some days it doesnt come on at all and other days its on most of the time. Any ideas?
