OC shop to install PF mirrors
Has anyone successfully had a shop CORRECTLY install (wire) Jdm power folding mirrors? if so please let me know which shop you recommend. Ive been searching for shops but they pretty much gave me the "ill can give it a shot" response.
Thanks H-T.
Thanks H-T.
why don't you do them yourself, it's really easy?? all you have to do is run the wires and look up the appropriate wiring diagram for your particular switch and relay
I wish it was that simple. Finding the jdm mirror wiring diagram is hard enough as it is. then trying to re-pin my stock mirror pigtail to take the 2 extra wires needed for the "retract" option is another thing.
i used this one...
http://i17.photobucket.com/albums/b5...orsDiagram.jpg
but since you have the one with the retract button ...it is most likely this one...
http://i9.photobucket.com/albums/a83.../ek9wiring.jpg
i used this one...
what sucks now is that my mirrors didnt come with the jdm pigtails. did you guys use your stock ones and modify them? since the jdm harness has 2 extra wires which the stock harness lacks
i say go to a junkyard and cut the pigtails because it's the same thing ..i personally ran all the wires ..but a buddy of mine just added the 2 wires because he already had power mirrors in his lx ..he just needed the folding option
