Excessive oil leak during winter months??
Old Jan 8, 2010 | 08:43 AM
gsrvong's Avatar
Default Excessive oil leak during winter months??
Ok, so I have the infamous honda leak on my gsr. It's most commonly the cam seal/plug, but I have replaced that 3 times, two oem, and one passwordjdm with the double o-ring. I have also replaced distributor o-ring, spool valve gasket and all but only held for about 2 months then it started leaking again from around the same area. During the winter months, it leaks so much more than it does summer time. Anyone know have some suggestions to why it leaks so much more during winter? And where my real problem could be?
Old Jan 8, 2010 | 08:55 AM
seanbev24's Avatar
Default Re: Excessive oil leak during winter months??
Maybe because the seal contracts in the cold? Are you using hondabond/permatex when installing them?
Old Jan 10, 2010 | 07:54 AM
gsrvong's Avatar
bump for more input
Old Jan 10, 2010 | 03:31 PM
Integra4lyfe069's Avatar
someone just tried to help you, u didint even answer him and you bump for more help? :S
Old Jan 11, 2010 | 09:38 AM
gsrvong's Avatar
You shouldn't have even posted because your post was useless. I read his post and answered it myself, YES I USED HONDABOND, happy? Anyone else have any other ideas why it would leak more during cold months?
Old Jan 11, 2010 | 09:46 AM
mouab18c1's Avatar
i guess its just how things work. i would say when its cold rubber seals get cold and shrink together and once it gets warmed up by the motor it would crack since thats what happens when you poor hot water onto a frozen window. just my 2cents but i recently just had to replace my oil cooler gasket, cam plug and cam seal but now with everything new i dont see any oil leaks anywhere
Old Jan 11, 2010 | 09:52 AM
Maluko's Avatar
so wats the cause for the leak? my damn LS has the same leak..i thought maybe it was like the gasket or something.
Old Jan 11, 2010 | 10:11 AM
mouab18c1's Avatar
bad seals. mainly cam plugs and dizzy o-rings
Ravincasting
Honda Civic (2001 - 2005)
Aug 24, 2016 06:39 AM
ochata
Jun 6, 2012 04:46 PM
jeremypr
Aug 2, 2009 05:05 PM
jeremypr
Jul 28, 2009 08:54 PM
danielblushtein
Mar 16, 2009 12:33 PM
