PARTING OUT 2000 Civic SI and garage parts! great prices listed! pa
ALL PRICES NEGOTIABLE, TRYING TO SELL EVERYTHING! a note to mention, this car was turbo and never seen weather, rain or snow. so anything you're thinking about buying know that NOTHING on this car is at all rusty. theyre about the cleanest 10 year old parts youre going to find.
PLEASE ONLY EMAIL ME ON PARTS LISTED, FRONT END CONVERSION, DOORS, TRUNK, AND BUMPERS ARE ALREADY GONE!!!
all quotes are based off of being picked up.
$1200-LEGIT with papers 1997 usdm COMPLETE GSR longblock!!! 73k miles
$1700-LEGIT with papers 1998 JDM COMPLETE GSR LONGBLOCK!!! 180psi compression in all cylinders, MINT! 38k miles
$225-BRAND NEW Airesearch Garrett t3/t4 .48 .60 turbo. 5 bolt hotside, retails for 1700, NEVER USED! MINT!
$1100-BUILT lsd 5 speed ls hydro trans, Carbon synchros from gearspeed, brand new 3/4 gearset from acura, absolutely MINT condition good for atleast 600whp with all paperwork.
$400-MINT 15" excel wheels with tires, 2 tires 100%, other 2 40%. knockoff rota slips. silver in color.
$complete 2000 civic si seatbelts, front and rear, everything. make offer
$40-obd2 gsr alternator
$30-obd2 bseries power steering pump
$80-usdm obd2 gsr engine harness complete!
$70-jdm obd2 gsr engine harness complete
$2000 si rad support, everything in pic comes with it. perfect for a 2000 front conversion or your wrecked car. make offer.
$COMPLETE 2000 CIVIC SI AIR BAG SYSTEM, SRS UNIT, HARNESS, AND BOTH BAGS. MAKE OFFER!
$ignition harness make offer
$complete center air control unit thing behind dash, everything but the blower motor. make offer.
$25-2000 civic si cowl, mint.
$100-2000 civic si 1" brake master cylinder
$15-winshield washer bottle n pump
$make offer - both air bags from my 2000 civic si, air bag wiring harnesses, and air bag computer!
$75 - chipped vtec 5 speed obd1 ecu with spare reburnable chip(can do basemaps)
$-2000 civic si FUEL PUMP and the sending unit, both $80
$50-200 - 2000 civic si sunroof setup, perfect condition. you can even take the whole roof skin depending on what you need.
$25-rear glass for 2000 civic si/civic dx, ex, etc. mint, tinted one piece
$10-left and right side quarter glass.
$35, 2000 civic si headliner with visors pickup ONLY
$100-front 2000 civic si brake setup, calipers, brackets, lines, and rotors included.
$15-b series clutch slave cyl.
$125-2000 leather si steering wheel with airbag
$20-2000 civic si bare dash
$15-40ea-interior parts, ask about them.
$60-black 96-00 complete PASSENGER SIDE quarter panel, VERY good condition
si/gsr b series parts:
$45-ls throttle body mint, tested the sensors.
$5-oem gsr oil dipstick
$30-dsm 390cc injectors
$110-em1 civic si seats out of my car. mint FRONTS only
$40-t3/t04E turbo. only has 5k miles and is mint but the compressor sucked up a piece of plastic from the air filter and ruined the cold side fins. just needs the compressor fins. no play.
$80-b16a2 '00 civic si distributer
$20- oem spark plug covers b16 or gsr
$15-oem gsr/b16a water pump, low miles
$30ea.-(2) jdm gsr/b16a oil pumps, no ckf sensor since jdm, need chipped ecu both have low miles
-(3) bare jdm b16a blocks, $85-needs honing, comes with crank, $65-one needs boring, the last is good for core fee(cracked ringland)-$50
$15-ARP rod bolts for d-series, 8mm ones, brand new, missing one bolt, fell out of package, 6 dollars from ARP. HUGE savings.
-(3) b16a2 timing belts, all under 15k miles, $5 ea.
$10-both trunk 50/50 tails, no qtr panel tails, just both trunk ones.
$20ea-(2)gsr/b16 factory oil catch can setups
$20-gsr crank pulley with bolt, no key, good if you need the oem crank pulley
$25-(2) oem tstat housings with water pipes
$50-b16 crank, mint
$40-b16 crank, one rod spun, still usable if repolished. did require largest bearing, now once polished will just step down a bearing color or two, ask for more info.
$10ea- jdm gsr oil filter water cooled housings(factory oil coolers)
$30-stock gsr fuel injectors, 240cc obd2 2 sets!
$40-GSR/B16 halfshaft
$40-stock b16 headers with downpipe
$30-stock gsr header
$40-stock 2000 civic si cruise control unit with acc's
$55-stock gsr butterfly secondary controller obd2
$15-stock 1.7 bar map sensor for obd2 bseries (have 4 of them)
$35-stock b16a2 fuel injectors obd1
$50-exedy stage one clutch kit for B-series, used, will need new clutch disk soon but the rest of it is great, was used in my 400whp si and couldnt handle the power. replacement disks are very cheap, its well worth 50 bucks for the pressure plate.
$15ea-(4) oil pressure sensors
$100-'98 civic ex power steering rack complete, same as '00 civic si.
a list of other stuff i need to sell:
$25-nextel i880 bad screen, its upside down
$30-nextel i710 mint
$30-nextel i850 MINT in box
$20ea-18x8" rims no tires, only have 2
dsm parts:
$45-brand new RRM CAS harness to convert 7 bolt to 6 bolt. retails for $80
$50-KNOCKOFF evo 3 big 16g with o2 housing. ported and comes with ss oil feed and coolant fittings.BLOWN
$8ea-interior plastic pieces, grey in color, door, (3)hatch cover, rear pieces
$50-stock 4g63 cams
$25-95 awd turbo cruise control unit
$100-fwd turbo act steel streetlight flywheel, used for 200 miles
$10-2g wiper arms
$30-stock dsm side mount intercooler
shoot me an email if interested in anything and remember parts are all OBO, i didnt really research prices im just trying to clean out my mess of a garage for the new project!
ask if you want pics. NO BS, IM SICK OF FLAKERS.
ONLY EMAIL OR CALL ME IF YOU SPEAK CLEAR ENGLISH, I ONLY SPEAK ENGLISH! Also, don't msg me asking how to do something, or if you dont have the money, DONT waste my time.
$50-b16 crank, mint
dsm parts:
$50-stock 4g63 cams
$10-2g wiper arms
pm's replied, feel free to msg me on aim people, ill be around pretty much today through sunday no work woohoo!
i may have over looked it but do you have an oem si lip??i cannot find one anywhere i had two but one broke and the other got stolen...let me know thanks
the oem si lip was absolutely destroyed in the accident :/ sorry.
i do have the heater blower under the dash and the dash is already half out, make me an offer on it!
T bracket and linkage i used in my new shell, sorry bro!
pm's replied, some stuff sold! thanks guys, lets keep this going, help me clear out my garage!
pete
pete
sorry bro the headlights are sale pending if not sold. i dont have a stock si shifter, the only thing i have is the shift boot/center console plastic and a stock shifter no ****.
pete
pete
Ok i would like the windshield, and some other misc stuff. I've got 50 for the windshield picked up. Hows that sound? Also do you have the power steering pump and full exhaust for an SI?
I need lots of stuff
I am interested in your SI front seats, Windshield, Power steering rack, maybe the padawan power steering delete and do you have instructions on how it hooks up?
I have two SI's and one is a shell I am trying to get back on the road.
Please PM or call me 757 871 6507
all PM's sent/replied! thanks alot honda-tech n people. helping me build my car for 2010 by selling off spare parts i have laying around is awesome.
shipping out a CRAPLOAD of stuff tomorrow, once i get that all out i will update the f/s postings.
shipped out lotsss of stuff today, all usps. i will pm everyone who bought stuff the tracking numbers later tonight, im on my phone right now!
pete
pete
BUY HIS STUFF!!!
got it shipped out bro. i didnt have time to clean it up but its seriously just dusty from sitting. you'll see when you get it, i sent you a pm with the usps number n stuff.
pete
pete
