NEED HELP WIRING DECK IN 89 SI
I followed this wiring information for my car:
1988-91 Honda Civic Stereo Wiring
Constant 12V+ Blue/White
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Driver's Pillar
Front Speakers 6 1/2" Doors
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers 6 1/2" Rear Deck
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
Result-NOTHING
it worked though when i connected my constant(yellow) and switched(red) together and connected them with the illumination wire(red/blk).
*I have to turn my lights on for it to work and it erases my memory.
also when its connected like this sometimes my inside light fuse is blown and i have to replace them and my trunk light is on but is very dim
any suggestions?
Ground Black
Dimmer n/a
Result-NOTHING
any suggestions?
does your stock harness still have the OEM plug on it? if so save yourself a headache and go get a stereo adapter from the auto parts store. purchase it once and it will come in handy from now on, every time you decide to swap in a newer better deck. or if you decide to swap back to original. and its easy as hell to connect, unless your color blind
nope just a bunch of wires.
i was planning to buy it though. but wanted other suggesttions.
hey man im connecting the **** same way i see it on the info and **** aint happening.
Check your fuses if you think everything is wired up right according to whatever you're looking at.
When I wired up the head unit to my old Camry I wired it all up the right way, didn't work, took it to an audio shop only have to have them replace a fuse I didn't see that was behind the dash and not listed on the fuse box label.
delsizzle1
Feb 21, 2011 01:09 AM
