cabin harness question
okay i have a 93 vx with a obd1 gsr swap. The car is going to be a track only drag car. So my question is.... is there a good writeup that i cant seem to find on converting the stock harness to run just the basic stuff you need...
NO ac
No heat
No srs
and does anybody sell these already done this way?
NO ac
No heat
No srs
As far as I know no one has ever done a write up on it. Honestly theres so little weight involved its not worth bothering with. The only time i've ever seen anything like what you're talking about done was on a tube frame chassis, easiest thing to do there is use a '96 - '00 Civic engine harness thats 1 piece back to the ECU and then run wiring for your guages.
msmurphy
Aug 22, 2007 09:15 PM
