color code of wires for 91 crx si
Old Sep 4, 2002 | 05:50 AM
vspec12's Avatar
New User
Default color code of wires for 91 crx si
I wanted to find out which wires where which fot the radio for my 91 crx si, the connectors have been completely cut off
thanks
Old Sep 4, 2002 | 06:37 AM
Louie B.'s Avatar
Default Re: color code of wires for 91 crx si (vspec12)
speakers:
Blue w/ stripe - left positive
Grey w/ stripe - left negative
red w/ stripe - right positive
brown w/stripe - right negative
I can't remember the stripe colors off the top of my head, but the stripe will be the same color on the right as it is on the left. the rears will have the same main colors, but different stripe colors. Use a 9v battery to "pop" the speaker to make sure you have the right wires. It wont damage them.
black is ground
red w/ black stripe is Illumination
constant if I remember right is white w/ yellow stripe
and switched power is either white w/ blue or yellow w/ red
I'm going off of memory here, so double check the constant and switched power with a meter before you hook them up.
brakedrum
Oct 16, 2010 08:57 PM
Crxfman6
May 20, 2008 02:02 PM
orangeracer
Mar 26, 2006 07:12 PM
Mr Ludecrs
Jan 5, 2003 01:50 PM
lodown414
Audio / Security / Video
Jun 19, 2002 09:44 PM
