2 layer head gasket????
Old Jan 7, 2010 | 09:03 PM
brandonschmidt's Avatar
Icon2 2 layer head gasket????
I was wondering if it would be safe to run a two layer head gasket in a ls/vtec with a .5mm over bore running pr3's with a b16 head and blox type b's?
Old Jan 7, 2010 | 09:56 PM
95skunkedgsr's Avatar
Default Re: 2 layer head gasket????
dunno did you clay the motor ?
Old Jan 7, 2010 | 10:14 PM
No. Haven't had the chance
Top Ramen's Avatar
That put's you at around 12.2:1 compression.
Old Jan 8, 2010 | 06:24 AM
Some people said they make a single layer gasket and they mill the head, do you think I would have enough clearance just with a two layer gasket?
Old Jan 8, 2010 | 11:04 AM
shiftmx179's Avatar
Has your head been milled or stock surface? Any other work to the head?
Old Jan 8, 2010 | 10:36 PM
Stock surface with no other work.
Old Jan 10, 2010 | 02:20 PM
Sol_Out's Avatar
Cometic Xtreme pressure ftw!!! =p
NSfit
Sep 20, 2006 06:43 PM
riceball777
May 17, 2004 07:10 PM
migo
Jul 7, 2002 09:54 AM
