how sould I clean my stock gsr pistons with???
Old Jan 7, 2010 | 06:18 PM
rotascircuit's Avatar
Default how sould I clean my stock gsr pistons with???
Hey I got a 95 gsr and I am doing a rebuild and I am using stock pistons. What should I clean the pistons with. Should I hot water them with soap? Sould I use steel wool with brake cleaner? Something that will not ruin them
THANKS
Old Jan 7, 2010 | 06:23 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: how sould I clean my stock gsr pistons with???
If you're doing a rebuild you'll need oversized pistons to go in the slightly larger bore. If you're just trying to re-ring some tired old pistons in a tired old block, don't worry about cleaning the pistons, you'll be rebuilding the block sooner than later anyway.
Old Jan 7, 2010 | 07:41 PM
nah bro I would never open the motor but do to a mis shift, I need to. pistons are fine just dirty. I honed out the sleeves so.... the motor ripped befor so it will happily rip now
Old Jan 7, 2010 | 07:59 PM
95skunkedgsr's Avatar
i dont think you are gettin what he is saying how much did u hone out the sleeves did u just resurface them or more and you could possible have some blowby with the motor now i think it would be best to bore .5 over or .25 if its a 81mm block and get some new pistons and im sure she will "rip" even better then befor
Old Jan 7, 2010 | 08:12 PM
true true but with college its tough to really spend so much money on her. I really want a dc2 ls or gsr cuz mine is 95hatch/95gsr. so want this thing to run, and maybe sell/trade it.
Old Jan 7, 2010 | 09:55 PM
u can get some oem type r os pistons pretty cheap and a bore job / head resurface isnt to costly ... save your pennys and be happy later
Old Jan 7, 2010 | 10:06 PM
igorka_91's Avatar
All he did was just get a ball hone and go up and down a couple of times till the walls were clean. Its a big hastle to take the engine out of the car etc etc. The block is still in the car.
Old Jan 7, 2010 | 11:08 PM
should be ight i guess aslong as it even
Old Jan 7, 2010 | 11:42 PM
.Manny.'s Avatar
Touching My Member
It's always more of a hassle when you have to rebuild twice
Old Jan 8, 2010 | 03:52 AM
OH_1fstgsr's Avatar
THANKS
To answer your orginal question. Acetone. Wipe down all your parts prior to assembly.
Old Jan 8, 2010 | 10:42 AM
I got to agree but we did the same thing to my buddy but install R pistons and thats it. runs good with no problems
rotascircuit
Jan 7, 2010 07:38 PM
Bgesy
Aug 24, 2006 04:28 AM
omahaturbocivic
Dec 3, 2003 01:44 PM
ysrhatch
Jan 19, 2002 05:45 AM
