Suspension & Brakes Theory, alignment, spring rates....
Recommend a good rear toe adjuster
Old Jan 7, 2010 | 02:21 PM
static-x's Avatar
Default Recommend a good rear toe adjuster
Im needing to get my rear toe fixed since the factory could only adjust to 0.25 on the left and -0.13 on the right. Car is a 91 crx. You guys recommend a good brand to use? Also if my rear toe was that much out of whack would it throw off the steering feel and make it more twichy?
Old Jan 7, 2010 | 02:28 PM
TunerN00b's Avatar
Default Re: Recommend a good rear toe adjuster
I'd recommend finding what part(s) is/are bent and replacing those instead of using a variable length toe rod as a hack fix.
But I believe that SPC makes them for your car, and they're a trustworthy brand.
And yes, rear toe out of alignment can cause a twitchy car with strange steering feel.
Old Jan 7, 2010 | 02:31 PM
static-x's Avatar
Nothing is bent actually. Could it be those energy suspension bushings in the trailing arms throwing the toe off? Or is something being bent the only possible cause. Ive had this car for 11yrs now and its never been in an accident except for the front right fender
ken-shin
Suspension & Brakes
Apr 7, 2006 08:31 AM
fireant
Suspension & Brakes
Jul 25, 2005 12:06 PM
CivicSiRacer
10
May 2, 2004 01:50 AM
SPiFF
Feb 7, 2004 04:49 PM
TheBestCRX
Oct 24, 2003 09:36 AM
