Vetc
Old Sep 4, 2002 | 04:46 AM
gavhowe's Avatar
Default Vetc
How can i lower the vtec point. Whats a MSD rpm switch cant mind anything about it on the net. will it work lowering the rpm point and will there be enough fuel to match cam.
Old Sep 4, 2002 | 04:50 AM
Xsi's Avatar
Xsi
Default Re: Vetc (gavhowe)
Buy a VTEC controller. Depending on your mods there may be no point in changing it, please don't say you want to be in VTEC all the time.
Old Sep 5, 2002 | 11:27 PM
Kamin's Avatar
Default Re: Vetc (Xsi)
only lower vtec if you are gonna have it tuned to see where the optimal point is
remember, vtec is where it is for a reason, you go below that, you bog. you go past stock you dont make power till vtec.
its supposed to be a good transition
the only time its really necessary to move vtec is if you get upgraded cams
Gator0302
Honda Civic (2006 - 2015)
31
Apr 6, 2010 10:19 PM
fryman
Sep 28, 2008 02:32 PM
EG_LS
18
Nov 2, 2007 04:09 PM
JDM00SI
Jul 18, 2004 11:06 PM
