A/C bracket for my LS into EK swap
Old Jan 7, 2010 | 07:46 AM
bori bori's Avatar
Icon2 A/C bracket for my LS into EK swap
I recently put an LS into my EK, and wanted to keep the a/c in it, so i bought, what i supposibly thought was, a b20 a/c bracket. When i put it on and in the car, I notice that the pulleys do not line up to put the belt on, and I cant put the bracket onto the motor mount aswell. Does any one know how to distinguish between a b20 bracket and any other? What is supposed to be stamped on it? I believe on mine it says P3G-1 and right underneath it, it says METTS.
Any help will be very appreciated, Thank You
Old Jan 7, 2010 | 07:50 AM
B16acivicsedan91's Avatar
Default Re: A/C bracket for my LS into EK swap
You need
38930-P7J-000 CRV Bracket
38930-P54-000 Del Sol Bracket
One of these two are the only ones that will work.
Old Jan 7, 2010 | 07:52 AM
bori bori's Avatar
yes, but would you know how to distinguish one from another different bracket? I want to know if my bracket is a B20 or did the guy I bought mine off from F@#$ me over.
Old Jan 7, 2010 | 08:01 AM
They will be stamped with P7J or P54 somewhere on the bracket. On the block side if im not mistaken. Someone correct me if I am wrong.
Old Jan 7, 2010 | 08:07 AM
jayWknight's Avatar
The stamp is on the front of the bracket. I had the hardest time finding the bracket used so I just bought a new one. I asked many sellers to verifed the stamping and none of them were p7j or p54.
Old Jan 7, 2010 | 08:09 AM
The crv one is the cheaper one from Honda. That might be your best bet.
Old Jan 7, 2010 | 08:14 AM
fastrxu's Avatar
Def supposed to have p7j cast into it
How much did you pay?can you return it?
Old Jan 7, 2010 | 11:28 AM
thumper64's Avatar
I can verify it is on the front side.
http://tinypic.com/r/1127dl2/6
I actually have two of these. That one I'm sending to another HT member and another just like it I was going to use so I could put AC in my car, but that's not going to happen because of a change in my plans...
if you're interested in one, PM me with an offer.
Old Jan 7, 2010 | 11:44 AM
lshatch98's Avatar
the METTS bracket i believe is single cam bracket
Old Jan 7, 2010 | 01:31 PM
thumper64's Avatar
I just did a search and the METTS bracket is for DOHC. Hmm, this is odd... Sure you're trying to use the right holes?
Old Jan 8, 2010 | 11:05 AM
bori bori's Avatar
yea, I put it on and both the tensioner and a/c compressor dont line up with the crank pulley. I think Im just going to have to go to HONDA and get a new one, It will be a little cheaper since I have a friend that works there, DISCOUNT!
blackcherry
Apr 28, 2012 05:00 AM
lil danny
May 1, 2009 07:05 AM
shake-zula
Aug 12, 2008 08:02 AM
arcboy
Nov 18, 2006 02:12 PM
