89 crx fuel line leak
Old Jan 7, 2010 | 12:08 AM
putzy07's Avatar
Default 89 crx fuel line leak
Hey I have a 89 crx si and right next to the fuel pump there are 3 lines that run under the car to the gas tank. One of these lines is leaking and forming a puddle in the car. It isn't a constant leak. Sometimes it barely gets wet, other times it is an all out puddle. Even if the car is at a full or half tank, it will leak. Basically I'm just seeing if it's possible to just cut off a section of the line and replace it and put on a clamp of some sort? Thanks
Old Jan 7, 2010 | 03:04 PM
toverby's Avatar
Default Re: 89 crx fuel line leak
Yep my car had the same problem and i just cut off the section that was slowly leaking and replaced it with 3/8 fuel injection gas line an put 2 stainless steel clamps on each end. it works fine.
Old Jan 7, 2010 | 11:21 PM
putzy07's Avatar
Awesome to hear. I figured that was the route to take. Thanks!
tolowhb
16
Jul 24, 2020 07:37 AM
vulch
May 8, 2015 08:09 AM
str8edgexx
Jan 28, 2012 02:08 PM
whiteturbohatch
Aug 16, 2005 01:01 PM
