91 hatch sunroof
Old Jan 6, 2010 | 08:09 PM
hurryup's Avatar
Icon5 91 hatch sunroof
I have a 91 civic hatch. I had a leak this morning from the sunroof. I think the back seal is worn out. I called honda and they said i would have to buy the whole glass. they dont sell the seal as separate. the glass cost $900. thats way too much. is there a easy and affordable way to fix this or anyone out there selling a sun roof? pls let me know.
thanks
Old Jan 6, 2010 | 08:17 PM
hatchet_honda's Avatar
Default Re: 91 hatch sunroof
try cleaning out your drain tubes....if the leak is pouring down your back like mine was it may be the rear tubes. they run along the roof and exit near the rear tailights..if you pop off the covers inside the hatch they will be right there. youll see the tube. mine had dirt clogging up proly 8 inches of the tube. used compressed air and blew the crap out
Old Jan 6, 2010 | 08:19 PM
and 900??? for the roof glass? jesus.....check this site. the seal IS seperate from the glass. http://www.hondaautomotiveparts.com/...tcgry5=SUNROOF
Old Jan 6, 2010 | 11:39 PM
hurryup's Avatar
Icon6 Re: 91 hatch sunroof
i looked at the roof a little closer tonight. lt looks like the glass is slightly of level. the rear seal is not tightly touching the roof line. any advice on how to adjust the level?
Ill check on the drain drain tubes tomorrow. I saw the tubes before when i changed my brake light, but i had no idea what those were.
ill also check on the site you posted. thanks
Old Jan 6, 2010 | 11:48 PM
prelude182's Avatar
yeah usually those tubes are clogged up by mold and residue from the weather. I had the same thing happen in my 89 prelude si except the cold *** water drained from my sunroof, to my neck, and down my back when i started backing out or came to a quick stop. it sucks but its an easy fix.
Old Jan 6, 2010 | 11:56 PM
hurryup's Avatar
thats exactly what happened to me this morning. sucks, right before work. but yeah i hope i have time tomorrow. its now 1 am in Hawaii kindah late but excited to check it out.
Old Jan 7, 2010 | 09:42 AM
mine is the same way..drivers side of the glass is higher than the passenger...i origanally thought it was the seal too. then i traced the draintubes down near the tailights and noticed the **** inside the ends. theres a lil black rubber boot on the end thats kinda sliced to let water trickle out, i pulled both them sumbitches off of there and tons of crap and water came pouring out. no unexpected showers while backing up since...
Old Jan 7, 2010 | 10:37 AM
Joberg's Avatar
New User
Yeah air compress it out
mickeywickit
Mar 14, 2015 08:49 PM
Jhicks
Mar 9, 2012 08:23 AM
InTheLBC20
11
Sep 4, 2009 08:26 PM
Rextified2003
11
May 12, 2004 09:33 AM
