93 coupe with OBD1 GSR swap Sell/Trade
1993 Honda Civic Coupe EX with 290,xxx miles
1996 Acura Integra GSR swap 130,xxx miles
Stock OBD1 GSR ECU
$4,500/Trade for low mileage, clean VX/HX/CX/VP plus cash
5 speed
Power everything
Manuel steering rack conversion
A/C
Teal exterior
Black interior
Black steelies with newer tires
A few scrapes here and there, nothing big. One rust spot on passenger rear quarter panel and one very small (dime sized) surface rust spot on the trunk lid. The interior is clean. The glove compartment opens crooked due to small broken plastic piece but works fine otherwise and the speedo is acting up, looks to be the VSS ( Vehicle Speed Sensor).The motor is stock except a brand new K and N cold air intake, Moroso oil pan and blox fuel pressure regulator. Huge service done about 5,000 miles ago including, Timing belt, water pump, plugs, plug wires, cap, rotor, fuel filter, transmission fluid change, radiator flush, complete axel replacement on both sides, O2 sensor, map sensor, front brakes and rear wheel bearings. This car will not let you down, it is very clean for its age and the swap runs perfectly. Mustninty@yahoo.com if you want more pics or info.
Stock OBD1 GSR ECU
5 speed
Power everything
A/C
Teal exterior
Black interior
Just to be clear I'm looking for a CLEAN low mileage gas sipper. I accepted a new job that has me commuting about 3,000 miles a month. I'm looking for a gas sipper with a lot of life left in it, not a project car. Also $4,500 OBO, not low ball the hell out of me.
classciv
Jul 26, 2005 07:40 AM
