1991 CRX si d16 to d15?
Old Jan 6, 2010 | 07:47 PM
BondoBuilder's Avatar
Default 1991 CRX si d16 to d15?
I picked up a 1991 CRX si with a blown the d16 motor. I have hopes of eventually doing a b18 swap, but in the meantime just DD it. I have d15 motor out of a dx civic. Will the si CRX run with that d15; will the harnesses plug in?
Thanks in advance!
Old Jan 6, 2010 | 07:50 PM
D16SiHatch's Avatar
Default Re: 1991 CRX si d16 to d15?
yep. just use the intake manifold and dizzy from the d16 on your d15.
Old Jan 6, 2010 | 07:58 PM
Cool!! Just curious as to why?
Thanks!
Old Jan 6, 2010 | 08:30 PM
D16SiHatch's Avatar
why use the stuff off your d16? because the dx engine is setup with dpfi and you will want to retain the mpfi of your old d16. it will make more power this way, and it's the cheapest way to get the job done.
Old Jan 7, 2010 | 02:40 AM
Thanks again!
Old Jan 7, 2010 | 09:59 AM
turbohatchBnuts's Avatar
i would use the head off the si to it haves different cam in it
Old Jan 7, 2010 | 11:10 AM
DCRB's Avatar
no need for head swap IF the o/p wanted to use the si cam, although it has been proven that the si cam is the same as a d15b2 cam, (search, there's a thread about it) just clocked differently.
o/p, if you want to use the si cam, you'll need to also use either a y8 cam gear or get an adjustable cam gear and adjust it like 4.5* one way or the other (i forgot) to make up for the deck height difference.
Old Jan 7, 2010 | 12:11 PM
its easier to just do a head swap with a cam already in
Old Jan 7, 2010 | 02:00 PM
Thanks for the input guys. Like i said this is just to get from point a to b... until I get some cash for the b series.
luckecharm2004
Sep 30, 2004 10:32 AM
tgreaves
Nov 14, 2003 10:18 AM
firstgenrex
13
Oct 8, 2003 06:49 AM
auto-x
Aug 14, 2003 06:02 AM
BoostedD15B7
Apr 28, 2003 10:29 PM
