1998 GSR ABS delete ?????
Ok i am gethering the parts to delet the ABS system in my 98 GSR. I have 2000 SI brake booster, master cylinder, and proportioning valve. Can I use the four brake lines from the SI or do i have to get integra 98+ Rs integra brake lines.
brake lines at checkers are 5 bucks for 36" of it. get a few of those. then idk if you have a harbor freight near you, its just a cheap place that selld tools. but i got a brake line bender and flare tool for less than twenty bucks. then you can run all new ones so its looks clean and keep them close to the firewall.
^^^tru. but, if your lazy like me and dont feel like f##ing up fifty times I bought the 98 rs lines ( the ones you need have to be 98 or newer) from delray acura for about 40 bucks. I installed them in about 40 mins. 94 to 97 lines will not work. you can actually keep your integra brake booster and master cylinder. I also used the SI prop. valve.
volcomstoned
Jan 14, 2011 04:11 AM
aznlaoboi315
Sep 3, 2008 04:03 PM
