how much do you think it will make???
okay so about a year ago i lost my license for a year. i thought to myself this is a perfect time to rebuild my motor so i did. ive been working on this for about 4 months finally about 3 weeks ago i got it swaped and running. now all i have to do is wait another month and a half to be able to drive it.
anyways heres the spec on it. i was wondering what you guys think. what number should it be putting up???
Engine
-82mm GSR block
-Wiseco 11.8:1 K566M82 pistons w/ rings
-Eagle big bolt rods
-Oem oil cooler
-ACL race bearings
-Moroso 4 qt oil pan
-New P72 oil pump and rear main seal
-CTR Crank Puley
-PR3 head
-Skunk2 Pro1 cams-Degreed
-New OEM cam seals
-Golden Eagle Vernier cam gears
-Supertech Valve springs and retainers
-Supertech standard valves
-OEM valve seals
-ITR intake manifold
-ITR throttle body
-RC 310's
-InlinePro fuel rail
-MemoryFab Whale *****
-Castrol 5w-30 w/ Honda filter
-New OEM timing belt and OEM P72 water pump
Transmission
-98 JDM ITR transmission w/ OEM LSD and 4.785 fd
-Competition clutch stage 4 - sprung 6 puck
-ACT Prolite flywheel 8.8 lbs.
-Advanced axles
-Honda MTF
Fuel Management
-Boomslang obd2b-obd1 harness
-P28
Exhaust
-Hytech Brushed S.S. replica header
-Kteller 2.5 tubing kit
-Vibrant flat black muffler
http://i114.photobucket.com/albums/n...9/SANY0038.jpg
http://i114.photobucket.com/albums/n...eper09/096.jpg
***my header is all f'ed up from being hit on the ground. i think im going to up grade to the kiddracing narrow rep. that may add a couple numbers**
let me know what you think? anything i could have done diffrent. any ecu suggestions. anything.
Engine
-82mm GSR block
-Oem oil cooler
-ACL race bearings
-CTR Crank Puley
-PR3 head
-New OEM cam seals
-OEM valve seals
-ITR throttle body
-RC 310's
Transmission
-Advanced axles
-Honda MTF
Fuel Management
-P28
Exhaust
I have no ideal about power production because no one except the builder knows anything about the assembly nor how well it will be tuned.
One thing, get rid of the whale ***** and find the correct length intake tube on the dyno.
As for a ecu, chipped p28 tuned with Neptune works for me.
im guessing he will at least rev it to 8500. no more than 210whp and that would be with a knowledgeable tuner...... you should take a look at the all motor dyno thread to get an idea.
With a 1.8L engine, revving to 8500 rpm, naturally aspirated, running pump fuel you will make a maximum of 230 HP at the crank. That is if the combination of parts you chose work well together and your tuner has gotten fuel mixture, ignition timing, etc correct.
230 BHP at 8500 rpm in a 1.8L engine corresponds to a brake mean effective pressure (BMEP) of 195psi. This is about as high a BMEP you will be able to get with pump fuel and that is only if everything is perfect. Likely, however, your setup is not perfect. A BMEP of 180 psi, which is more likely and reasonable, would yield 210 BHP. Take of 15% for drivetrain loss and your looking at a realistic 178 wheel Horsepower. Your result on a dyno will likely be this amount or less. If you use a dynojet you may get a higher reading, however this is not a true horsepower reading. It doesn't mean a dynojet is not a good tool, it just means the numbers then tend to produce are optimistic.
BMEP has been used by professional engine designers to accurately determine how much horsepower an engine will produce for a 100 years. Any dyno is a tuning tool and nothing else. If you are just looking for the highest whp number you can get so you can brag to your buddies, then you're just bench racing.
gotta hand it to ya Scott, you can really break it down. i bet if he chose to go with 84mm pistons, S2 P2 cams, some head work along with a functional intake system and a custom header i'm sure he could see 210whp.... that is if the tuner has everything dialed in at its best
thanks alot guys. scott you really know you stuff man
....props.
i was hoping arround 200ish bhp. and im am reving to 8500rpm. ive been looking at some intake system stuff. tb, manifold. betting intake.
....props.
Sorry Scott, but I know of several builds exceeding 220 whp. Check the dyno thread at the top of the forum. I don't know about this build.
Nobody can tell this guy with 100% accuracy what his WHP will be until he has it dyno'd. We can only tell him the maximum number he should possibly see.
Last edited by Scott_Tucker; Jan 7, 2010 at 12:24 PM. Reason: technical additions.
Thank you, I had good teachers. I think that is a good, realistic goal. I can't stress enough that a dyno is only a tuning tool and the exact number does not matter. The true results will show themselves at the track. You could measure it with monkeypower instead of horsepower and as long as you got consistent readings and were using it as the tool it was intended to be.
PirateMcFred
158
Apr 14, 2011 10:50 PM
