Brown Coolant
So I checked my coolant today and its brown, my initial thought was that I had a bad head gasket or a cracked head, but wouldnt the car over heat? The car runs at normal temperature. Although ocasionally when the car comes to a stop it shuts off. I heard that when you mix different types of collant together it can change the color. Could that be the case? Any other ideas?
If the coolant isn't changed often enough, it will get impurities in it and turn brown, rusty brown, etc. That could be what's going on with yours.
Where does the coolant look brown? In the overflow tank?
on mine the brown coolant is brown in the radiator and in the overflow tank. what happens if it is slimy or sludgy brown? just wondering, i haven't checked if mine is like that but my car turns off periodically as well so im wondering if has anything to do with it.
Personally any time I have seen a blown head gasket make a car stop running. It was blown enough that there was a blanket of white smoke coming out the tail pipe. There was more coolant than fuel in the combustion chamber so the cars stalled.
Is your check engine light coming on?
No check engine light, and no smoke on the car too. It ran fine besides that it would shut off every once in a while
I would suggest looking at testing the PGM-FI main relay. Specially if your car is shutting off sporadically with no CEL. A shop manual is a must to trouble shoot ghost problems like this.
it starts right back up. it stops only when the motors cold and when its cold outside. and its when im slowing down from like 50 to a stop and it dies at like 5 or so
Sounds like you may need to run the idle learn procedure and also may have a bad main relay as well.
If it's not a ULEV, then chances are low that the head gasket is bad unless it was overheated severely. Probably just has old/mixed/coagulated coolant. Do a cooling system flush with regular green coolant as others have recommended.
OP if you need a shop manual pm me with your email and i will send you a pdf copy. i would host it and post it up here but i'm pretty sure thats against rules. (i remember something about no pages from haynes/chiltons being posted and i assume the same applies here.)
