95 eg coupe gzr swap problems with ecu!
Old Jan 6, 2010 | 01:02 PM
bdassdrummr's Avatar
Default 95 eg coupe gzr swap problems with ecu!
I have a 95 eg coupe. i have a gsr swap and got the p72ecu chipped about a month ago and everything was working fine. they put 2 step in which holds the car at 4000rpms staying still, redline is 8500 and when u hit 8500 the check engine light goes on as a shift light. the stock tach redline is shown at 7000. i gunned it on the fwy today and it wouldnt go past 7 grand even with the chip. the 2 step still wrks tho. so i tried my friends ecu which is set to redline at 8500 and it did the same thing and wouldnt go past 7 and the check engine light goes on at 7 now too as the shift light. anyone kno what is wrong?
Old Jan 6, 2010 | 02:14 PM
Relic1's Avatar
Default Re: 95 eg coupe gzr swap problems with ecu!
failing ignitor, coil or tach.
Old Jan 6, 2010 | 03:14 PM
fasthatch95's Avatar
if vtec pressure switch isnt wrkn it will do that
Blainet96
May 27, 2015 03:28 PM
egrunner
May 8, 2014 05:50 AM
HungLoSavage
Sep 19, 2010 06:07 PM
daymkimchee
Nov 24, 2008 09:12 PM
