can anyone find a diagram for a crx si
You can test for spark without a light tester but be careful. Also, and I've done this many times before, after installing a new distributor did you plug in to the 2 plugs that go from the harness to it?
I should ask these questions:
What caused the car to not want to start in the first place? Why did you replace the dizzy? Did you just change engines? Engine rebuilt? What else have tried or verified?
all i did was change the engine harness, i figured since it wasnt getting fire i needed a new dizzy the ecu is throwing a code but its iac or somethin like that
http://techautorepairs.com/ignition.html
also check here for more troubleshooting on main relay and ignition
The IAT? Is it code 14? Yes, your engine needs to know the intake air temperature to run. That's an important piece of information for the ECU... Helps control things like idle, injectors, fuel and the such...
do u know what the wire colors are that go to the iac and i just switched out a cut si harness for one thats not cut but im havin trouble findin where some plugs go
Code 14 is for the Intake Air Control Valve on the back of your intake manifold
You should have 8-15 ohms of resistance between the terminals on the IACV and no continuity to ground.
There should be battery voltage at the 2p connector that attaches to the IACV aswell.
