si cam into std
Old Sep 3, 2002 | 11:39 PM
brbHPR's Avatar
Default si cam into std
i hear that it'll be off 1/2 a tooth. why?
and, i also hear that the 91 cam is a little more agressive, anyone able to verify?
thanks!
Old Sep 4, 2002 | 10:32 AM
Urban Business
Guest
Posts: n/a
Default Re: si cam into std (brbHPR)
shouldnt be off by a tooth. its the same cam as the std just larger duration. and yet is it more agressive, extended your power curve to about 7500rpm. HOWEVER you will have to upgrade your std valve train other wise you will stretch everything reving that high
also all 88-91 si cams are the same
[Modified by TorteX, 1:33 PM 9/4/2002]
Old Sep 4, 2002 | 10:53 AM
wronghand's Avatar
Default Re: si cam into std (TorteX)
Here is some info on the cams:
https://honda-tech.com/zerothread?id=238126
[Modified by wronghand, 2:55 PM 9/4/2002]
Fo-Do Fanatic
Oct 5, 2011 02:49 AM
Al_90HB
Dec 3, 2010 10:23 PM
Sheep
29
Apr 2, 2007 11:01 PM
GreenBean
Jun 3, 2005 12:20 PM
Urban Business
May 9, 2002 12:45 PM
