DOHC Zc Throttle body w/ Z6 Intake mani
Would a dohc zc throttle body and a z6 intake manifold be a good idea to swap into my car over the stock Si intake manifold? Keep in mind im doing a y7/y8 mini me in a the near future with p29 pistons and im trying to avoid buying a y8 intake manifold because i do not want to spend the money.
Yes, it would be worth a little bit of power. The sohc vtec intake manifolds flow better than the stock D16A6 manifold. Not going to be worth 25 horsepower, but it will provide proven gains, especially in the higher RPM.
the OBD0 DOHC ZC throttle body will not bolt onto the D16Z6 intake manifold - different bolt pattern - the OBD0 DOHC ZC throttle body is the same as the D16A6 throttle body
ahh ok, i wasnt into the tear down process to see if they would match. But you guys saved me a little bit of time. So i take it the dohc zc intake mani will not bolt onto a d15 or d16 head?
racedoutsi
Mar 25, 2002 05:53 PM
