WTB: Full 5 sp swap for my 97 Base Prelude
I'm looking to do a 5 speed swap on my 1997 Base Prelude, so I'm looking for the parts to do it. I would love to get a full swap from one person, but will pick up parts here and there. I would love for the tranny to have under 150k on it. This is a list of the parts I need:
Helms Manual (VERY IMPORTANT) Helm Inc
Transmissions Assembly (97+)
Trans mounts-side
Engine Mount-rear (rear is optional-the rear auto mount will work)
Flywheel and bolts
Clutch Kit and bolts
Clutch Master Cylinder
*Clutch Slave Cylinder
*Clutch Dampener
*Vehicle Speed Sensor (VSS)
*Reverse Switch
*Hydrolic Lines
*5spd Starter
Clutch Pedal Assembly
Brake Pedal Assembly
Shifter Assembly
Shift linkage
Auto ECU or 5speed ECU
5spd Intermediate shaft (half-shaft)
5spd Gauge Cluster (optional)
Cotter Pins (assorted sizes)
Assorted Nuts and Bolts
Also, if anyone knows of a shop or person who could do/help with the project in the St Louis area, I would appreciate it. Thanks.
Trans mounts-side
Flywheel and bolts
*Clutch Dampener
*Reverse Switch
*Hydrolic Lines
*5spd Starter
Shifter Assembly
Shift linkage
draneusmc
Jul 24, 2003 11:15 PM
