brake proportioning valve
i just want to confirm about prop valve on my disc brake swap.
96 ex (si in canada) model
integra rear disc brakes.
i did search about these, im going to replace the correct prop valve but until it arrives (or found one in the junk yard) i still have the original prop valve.
did a test drive after the swap and steering is wobble, it feels like the rear tires are skidding left/right but not dragging.
did an alignment and everything is out of spec, after alignment (backs have a little bit of toe R-0.8 L-0.4) the left rear was adjusted at that deg due to the right being maxed out.
after an alignment, it's a little better on high speeds but still wobbling on low speed. today, started the car and did a spin around the block and same thing happened, after the car warmed up, the steering is back to normal.
im not sure if the + toe at the back causes this or the PROPORTIONING VALVE.
so before i look up or order the correct prop valve (part# 46210-s04-902)
i need your honda knowledge first.
thanks
thanks
i know where to get it, in fact i just ordered one from a CX model, i believe all SIR in canada are equip with ABS and the parts guy gave me a different part # for SIR.
i would like to know the symptoms of keeping the EX prop valve with disc swap at the back.
i read at sticky that one symptom would be your car will feel like out of alignment. i would like to hear other owners who swap their rear brakes and kept the prop valve (EX coupe)
ps. i believe the toe won't cause the wobbling steering, after an alignment yesterday, i found out my front toes were out of specs! and been driving like that for the past 100,000kms with no affect on steering.
So im looking towards the prop valve.
uberEFtuner
Aug 4, 2014 10:09 AM
crexer
10
Apr 17, 2004 09:13 PM
acura, brake, brakes, conversion, crx, disk, honda, installation, integra, prelude, proportion, proportioning, rear, sir, tech, valve
