92 si brakes problem
Old Jan 5, 2010 | 09:11 AM
honda305's Avatar
Default 92 si brakes problem
my friend has a 92 civic si and when he drives around his brakes are fine but when he makes a U turn or goes into reverse his brakes give out and he has to pump them a few times to get them working again. what could be the problem?
Old Jan 5, 2010 | 09:31 AM
Manny 77's Avatar
Default Re: 92 si brakes problem
Check for a leak if he have to add brake fluid you have a leak,(thats what sounds like) check the calipers front and rear if you dont see any leaks then replace the master cylinder... Oh question did you guys mess with the brakes at all??? if you guys did then could be air in the system... hope this help.
Old Jan 5, 2010 | 09:57 AM
honda305's Avatar
the fluid level is fine and no we didnt mess with the brakes. this started happening out of no where.
Old Jan 5, 2010 | 10:00 AM
Manny 77's Avatar
Master cylinder going bad replace it...
Old Jan 5, 2010 | 10:30 AM
honda305's Avatar
but its not leaking tho
Old Jan 5, 2010 | 10:34 AM
Manny 77's Avatar
is just not making pressure... dosent have to be leaking to be bad.
90 ef
Oct 29, 2009 12:03 PM
BlitzSix
Oct 28, 2008 04:28 PM
lupillo
Jun 24, 2008 11:47 AM
90civSi
10
Dec 15, 2005 11:35 PM
_BEN_
Jul 4, 2004 10:51 AM
