rear sway bushings 2002 accord SE 4cyl
so i need to replace the rear sway bushings on a friends 2002 accord SE... and poly bushings are about the same price as rubber, if not cheaper. so why not use poly... right?
my question is, i found prothane has a kit that is sometimes stated as being for 98-01... i assume this is a mistake seeing as how the 6th gen US accord runs from MY98 to MY02.
also, 16mm correct for the 4cyl? 17mm was on the V6 correct?
prothane site shows part# 8-1126 for 98-02 w/ 16mm bars and 8-1129 for 98-02 w/ 17mm bars
the front on the other hand are engine based. 4cyl has a 26.5mm front bar and v6 has 27.2mm bar. number of doors are irrelavent
XiOus271
Jul 28, 2006 08:55 AM
