get it out!! turbo manifolds, clutch line kit, f2 suspension, bf drag radials
FCS clutch line kit. this kit is for clutch master to slave. eliminates all the oem lines to the slave. looks really nice. comes with 2 fittings and ss line with clear jacket.
65.00 shipped
f2 drag suspension new in the box.
800 front 1000 rear. fully adjustable, 32 way dampening, preloadable, ride hieght adjustment.
850.00
b series twin scroll manifold w/ twin wastegates
accepts tial 44 wg or equivalent v band type wg. mock up only
860.00
bf goodrich drag radial 225/50/15 new only one pair.
280.00
1/4" d.o.t. air brake push lock vaccum / boost kits
everything you need to plum your turbo or vaccum lines. stainless steel fittings with high temp high impact d.o.t approved fittings and firestone d.o.t air brake lines.
plum your twin wastegates, boost solenoid, b.o.v, fpr, boost ref, and vacuum all in one package
95.00 SHIPPED
top mount manifold b series.
NEW b series top mount for t3 and t4 turbine housings. has both bolt patterns for turbine applications. accepts single tial 44mm wg.
750.00
FCS brake line kit new in the bag with clips,bolts,washers,etc. lines comes with mounts and a clear jacket to cover the ss braided line. fits civic/integra, ek, da, em very nice. sells for 139.00 just removed it to take pictures.
95.00 shipped
hellomrparks@yahoo.com
aim:jparks8832
65.00 shipped
850.00
860.00
280.00
95.00 SHIPPED
750.00
95.00 shipped
aim:jparks8832
