Popping sound in sharp right turns (not the axle)
Old Jan 4, 2010 | 12:32 PM
silentkid's Avatar
Default Popping sound in sharp right turns (not the axle)
Ok i recently replaced my driver side axle cause the boot wripped and today I replaced the passenger side axle cause when I would turn to the right sharply I got a loud clicking sound which made me believe it was the axle both axles are 100% new not used or rebuilt, new inner and outter tie rods and ball joints , new brakes and pads, I did recently do a swap but the axle clicked when turning to right with the previous swap as well.
Don't really know what it could be at this point
and it's definitely a rotational clicking type of sound
Old Jan 4, 2010 | 01:05 PM
silentkid's Avatar
Default Re: Popping sound in sharp right turns (not the axle)
Any help will be greatly appreciated so I can take this new setup to the track already lol
Old Jan 4, 2010 | 01:14 PM
wannaBjdmca6's Avatar
did you use the correct axle?
how low is ur car?
how did the replacement go? smooth?
Old Jan 4, 2010 | 02:47 PM
silentkid's Avatar
Axle swap was as smooth as can be Car is decentlynlow not dumped since I'm tryna go for a road race setup more then super low with crazy offset for now even though I wana but I'm not even that low and I'm getting weird problems already I
a try getting a pick up of my drop IRS really not that low though
Old Jan 4, 2010 | 03:22 PM
hbcrazy88's Avatar
if your sure its not the axels, it could be the wheel bearing because that would only make a noise when turning one way. but then again its not usually a clicking noise. if you cant figure it out, take it to honda and let the experts tell you whats wrong and then you can replace it lol.
Old Jan 4, 2010 | 03:39 PM
silentkid's Avatar
Lol. That's true I got some buddies that work at Honda I'll ask for there opinions tommorow as well... Hopefully it's something not to serious but with my luck I've had with this car I'm sure it won't be
Old Jan 4, 2010 | 06:48 PM
dayungking's Avatar
New User
when you find out post it up. ive experienced this myself and never found out whats the cause lol
Old Jan 5, 2010 | 10:48 PM
silentkid's Avatar
^ no problem will do
still working on it...i went to an empty parking lot an drove in circles...it doesnt sound like its coming from something internal as in transmission... honda was kinda busy today so didnt have time to get the buddies to take at it... i think im going to have a freind try to listen for the sound as i drive in circles with the hood off (just incase so it doesnt fall on there head hahahah
Old Jan 6, 2010 | 10:17 PM
silentkid's Avatar
had the car up in the air today at a freind shop to check things out..
well apparently the boot on the axle i put in at the beginning of november when i did the swap is wripped already kinda pissed me off but it should be covered under warranty
and also i realized the axle seamed to be kinda loose towards the half shaft but the axle doesnt push in any further and doesnt slide out either
when i shook the axle it seemed like the only thing that could be causing the sound when i make sharp right turns i would expect it to be done when turning to the left but as of now i have to warranty the driver side axle and then also i guess check if the half shaft bearing is done for hopefully thats what my problem is
Old Feb 25, 2010 | 05:39 PM
silentkid's Avatar
i figured it out a while ago...but it ended up being..even thought i swapped the driver side axle...and then still had a popping sound and swapped the passenger side axle ( both were new not rebuilt) the driver side axle boot had wripped and was the one popping again....got it replaced...havent had any problems so far
jimmy o.
Dec 31, 2009 04:51 PM
213374U
May 28, 2007 08:38 PM
Ilovemyef9
Feb 20, 2007 08:12 PM
95GSRTT
Aug 4, 2004 10:01 PM
penney
Apr 16, 2004 06:58 PM
