1990 Crx si turns by it self
My crx has like a mind of its own. When my foot is on the gas it does not do anything that bad. When im just coasting it turns either left or right. I think its the control arm bushings. I can wiggle the control arm. Any one know where i could get bushings?
mine also does this, and everyone tells me it needs an alignment but then wouldnt it constantly pull to a certain side? and also does yours turn if you shift fast too?
I suggest upgrading those old worn out bushings with some fresh performance polyurethane components. Energy Suspension makes a master set that includes all bushings needed except for the rear trailing arms. (sold separately for some reason?) Here's a link to the cheapest price including shipping I could find! Good luck with your build
http://www.streetsideauto.com/produc...GoogleShopping
maybe your rack in pinion is bad because my ef was doing the same thing and when i changed the whole rack in pinion assembly and got it aligned it work perfectly..
my crx has coilovers on the front and lowering springs in the rear and it sits with the left side lower than the right and it pulls to the right side if i let go off my (momo) wheel. And my front 2 wheels look like they are leaning in.(alingment issues). I think that i need strut bars to coilovers in aline.
OP: Have the car inspected and replace all the worn out and broken pieces. The fact that you can wiggle anything is scary as hell, nothing should wiggle, ever! Repair before you think about adding any other things to the car. Don't risk your life, your passenger's life or the life of someone else out on the road.
You'll thank yourself when you fix all the worn out parts. Car will drive amazing
IrishRex
Aug 21, 2003 07:35 AM
