F20B6 in my 4th gen prelude
Old Jan 4, 2010 | 10:03 AM
EdgarsBrenholms's Avatar
New User
Default F20B6 in my 4th gen prelude
Anyone have some information about F20B6 engine part sizes? Where can I get this info!!! Plz help, thanks for any information!!!
Old Jan 4, 2010 | 10:32 AM
supra-n-civic's Avatar
Default Re: F20B6 in my 4th gen prelude
it would be a fairly straight forward swap. the f20b is a very similar to the h22 in many ways. the motor mounts trannys and wire harnesses would plug in a abolt up the only thing id think you would need is the proper ecu for it. they are a nice motor and uncommon here in the states so im a fan of them.
Old Jan 4, 2010 | 02:57 PM
pentaq's Avatar
No, no. F20B6 is OBD2 SOHC VTEC met in Euro 6 gen Accords. Nothing special.
What do you need to know about parts for this engine?
Old Jan 4, 2010 | 09:53 PM
blklude5g's Avatar
all f & H's are straight compatable with the obvious acception to the f20c - but i do know there is a f20b that is very very similar to the h22 - and its an cast iron or aluminum block ( which slips my mind) but i do know it makes about 200hp at the flywheel
Old Jan 5, 2010 | 06:58 AM
nus_dogg's Avatar
Since its a SOHC VTEC motor, I'm pretty sure its similar to the F23A1 motor except for the block.
Old Jan 6, 2010 | 06:17 AM
blklude5g's Avatar
from wiki:
Displacement: 1997 cc
Configuration Valve: SOHC/DOHC, 16 valves, VTEC/Non-Vtec
This engine came in SOHC in vtec and non vtec, there is also a DOHC VTEC version of the engine, they all share the same engine code although they are very different.
The DOHC VTEC version comes with a blue powder coated valve cover as the H23A VTEC from the japanese accord sir-t. They're called BLUE TOP and are only from japan.
DOHC VTEC Manual Version:
197 HP @ 7200RPM
145 TQ @ 6600RPM
11.0:1 CR
85mm bore
88mm stroke
23mm wrist pin
145.5mm rods (f20b rod length = 145.425)
1.65 r/s ratio
55mm mains like h22a4 block
rod journal has been offset ground on both sides to the size of a b-series rod journal.
Old Jan 9, 2010 | 04:08 PM
New User
With some hybrid actions, I can get the same power as JDM 2.2 vtec... maybe more, I have some ideas to make this engine about 230HP
All this experiment is to get my prelude for dragrace in class 2.0
Sorry about my english!!!
Old Jan 11, 2010 | 01:20 AM
pentaq's Avatar
Anyhow I doubt it. It's 80hp over stock and if you retain the stock displacement it's not an easy task.
MyHotsh
Jun 5, 2008 02:53 PM
91accordcpe
Apr 21, 2007 03:41 PM
mnmfan
Nov 16, 2005 04:55 PM
Siegfried
Feb 29, 2004 06:21 PM
95redcivicex
Sep 11, 2002 08:23 AM
