rear sway bar in 90 civic
You can mount an 15?mm SI sway and if that one wouldn't be thick enough for you you could mount an ASR brace and matching 24 or 32mm hollow sway.
I don't think a DA swaybar will fit (good), but I could be mistaken.
You should do a search here on HT, ther's plenty info abound.
Factory Sway bar sizes
front. the letter is painted in the middle of the swaybar and embossed on the side of the bushing.
F = 19mm solid - all 4 door civics and wagon
G = 17.2mm hollow - CRX HF (Civic STD had no front swaybar)
H = 18mm solid - 3dr Civic/CRX DX, Si
K = 23mm hollow - DA integra
rear. the number is embossed on the side of the bushing. I believe they are all solid.
13.0mm = 3dr Civic Si
15.0mm = CRX Si
14.7mm = 3dr DA integra (doesnt fit EF perfectly, see explanation below)
15.9mm = 4dr DA integra (doesnt fit EF perfectly, see explanation below)
16.0mm = JDM SiR / EDM VTi CRX w/ B16 (uses a 15.9mm bushing)
You can see these posts on the crx FAQ for pics
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-i-put-da-rear-sway-bar-my-dx-hatch-pics-galore-1146145/
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/diy-adding-oem-sway-bar-your-std-dx-hatchback-2649526/
15.0mm = CRX Si
not a DA swaybar then...
btw, DA and EF hardware are different too. the angle bracket is completely different, but if youre fabbing and cutting holes or whatever, then it doesnt matter.
mynameizstitch
Jul 22, 2012 10:44 AM
ThefirstPACT
22
Feb 8, 2005 11:42 AM
juicy.koreans.suck
Jun 5, 2002 06:58 AM
