Accord Brake Problems
Question....
Im new to this so help me out!
When ever Im on the freeway going 65MPH and Im about to exit off an exit. I step on the breaks to slow down my car and at the same time my steering wheel shakes like heavily to the left and right, but not too heavy yet. Breaks are good and front rotors are in good shape. This only happens when I am going at a High speed (65 & ^). Not on low speeds.
Now can anyone help me out with this or knows what I should do.
Thanks
tkhang
Thanks
tkhang
Usually (or at least in my case) this was indicative of warped rotors...
I thought that wasnt the case, but the moment I changed the rotors, problem was solved...
Yup, that means you need new rotors unless you've just replaced them. I learn that if you drop or hit a brand new rotor on a pavement hard enough, you'll warp them. You'll need a dial indicator to check for warpage.
yeah i think that my also be the problems too, but didnt really feel like getting new rotors. Well I might as well change them to see wat happends.
No I haven't checked it yet but right now I am storing it due to winter. I will check that as soon as it gets warmer and I think I will need to replace them soon too, but they are still in decent shape as of now.
I'll check on that dial indicator first, n see whats up..
thanks
I got a 94 Ex 4dr Accord. I might just go OEM style rotors cause pads still have plenty of life left. Not a easy job yes i know, but gonna have to start somewhere. Usually Someones always there to help out if I got a problem (hands on). Yea I can get new ones just in case too.
thanks
thanks
Check your upper ball joints while your under there. It's easier to check and replace a couple of ball joints than it is to replace a rotor that may or may not be warped. I had a high speed shimmy in the steering wheel and I thought that it was my rotors, but it was my upper ball joint. If your rotors are "warped" you will still be able to feel a pulsating sensation in the brake peddle even at lower speeds. Just throwing that out there for ya.
Danutdlp
Mar 20, 2007 06:30 PM
LOWLIFEHATCH
Feb 22, 2004 08:06 AM
