my 89 crx si gets really squirly on the road?
Old Jan 3, 2010 | 03:55 PM
98gsrintegra's Avatar
Default my 89 crx si gets really squirly on the road?
Would anyone have any idea why my 89 crx si, get really squirly going down the road. alot when you get on it, it is lowered, but so is my integra, and it drive down the roaad just fine.
Old Jan 3, 2010 | 03:58 PM
project91crxsi's Avatar
Default Re: my 89 crx si gets really squirly on the road?
idk mine does this bad on windy days cuz its so light
Old Jan 3, 2010 | 04:02 PM
well i have a kid that wants it , but he says he dont want it cuz its so squirly. in my opinion, its not that bad, but i gotta get it fixed cuz i need a daily , and the crx dont have a title ;( so hes gunna trade me a DD
Old Jan 3, 2010 | 04:22 PM
Pinja's Avatar
Drunk Wagon Pilot
You know there's other suspension components that affect drivability right?
Old Jan 3, 2010 | 04:36 PM
when i bought it the kid had suposedly replaced, every bushing and suspension part
hmm steering?
Old Jan 3, 2010 | 04:38 PM
crazyboy's Avatar
then get under there and double check his work, are the bolts tight? did he in fact replace everything or just tell you that? i always double check stuff when another person touches my car
Old Jan 3, 2010 | 04:43 PM
.Manny.'s Avatar
Touching My Member
does anyone ever get underneath their car to check it anymore? Make sure everything is in good shape and tight
Old Jan 3, 2010 | 05:00 PM
well its cold as ***** out and sleeting rightn now. so i was try to get some ideas b4 i went to look at it.
Old Jan 3, 2010 | 05:42 PM
churn dasher's Avatar
check the back wheel bearing wiggle the wheels see if they move with the brake off and wheel off the ground
Old Jan 5, 2010 | 09:57 AM
WhiteSTi's Avatar
Negative camber?
Old Jan 5, 2010 | 10:09 AM
turbohatchBnuts's Avatar
this is why nobody works on my car except me hahaha
Old Jan 5, 2010 | 10:28 AM
4g4dcruisin's Avatar
you need to be more specific when you say "squirly". do you mean vibration, pulling to the left/right, overly bouncy, or what exactly.
-outer tie rods, meaning your Toe could be jacked up instead of your tires pointing | |, it could be like | \.
vibration
-again with the tie rods, if one tire is turned slightly to either side, you'll have bad vibrations the faster you go since one tire is essentially "draggin" while the other is rolling forward.
overly bouncy
-shocks blown, springs worn out.
but over all you need to get your hands dirty and check all bushings, bolts, and nuts related to your steering/suspension. wont take long, just jack up the front end and look for worn out bushings, tug on your LCA's and see if there is any play.
Old Jan 5, 2010 | 10:34 AM
crdizzle6288's Avatar
front end or rear feels squirly?
Old Jan 5, 2010 | 10:35 AM
EFWhite's Avatar
First thing I would suspect would be the toe-in maybe or a loose tie rod. My friend has a Mini-S and his car was doing something similar and he found out that after he had Global Imports BMW (The devil) work on his car (this was not the first time they screwed up) that the tie-rod was not bolted down completely and that caused some...how should we say...interesting handling characteristics
98Mystique2
Apr 24, 2017 12:24 PM
bigness
Jun 6, 2015 06:16 AM
h22_crx
Nov 11, 2005 11:22 AM
DevSys
24
Sep 17, 2001 05:08 PM
