Name These Under Dash Connectors
alright so I'm working on wiring and was just wondering what these particular connectors are for. are brown connectors all diagnostics related?
In the third picture, im wondering about that brown connector, but also if that white box/circuit thing under the hood release is for keyless entry or A/C. it says A/C and how compliant it is with things on the label. If thats not for the keyless entry then where is the keyless entry antenea?
edit: Car is OBD1 now. originally OBD2B.
The first brown one your fuel pump relay, the metal one is for your antenna, and the last two are power block things. If I'm not mistaken, there is at least one hot wire that goes into them and power the rest of the wires. I'm not totally sure on that though. Maybe someone else will chime in for you.
That is correct. I have removed 2 and installed 3 this week. I don't remember plugs and pin numbers to power wires. I have alldata pictures of all plugs and locations if need just pm me
thanks guys. I was lookin' under the dash yesterday and remembered the relays i unplugged there.
Still need to know what that white box thing in picture 3 is.
muddmonky
Oct 16, 2012 08:57 PM
scubadorg
Jan 4, 2005 08:36 PM
