FS: Complete K20Z1 Swap|100% legit
Old Jan 3, 2010 | 11:16 AM
92EGK20's Avatar
Icon4 FS: Complete K20Z1 Swap|100% legit
The time has come to part-out my ’92. The car was built in September of 2007 where the K20Z1 that is in it, had 4,982 miles. Motor was rebuilt in February 2009(see motor specs).
The motor and transmission are 100% legit. They came from my 2005 RSX Type-S that was wrecked. I would like to try and sell the motor as a whole before resorting to parting out so PLEASE DO NOT ASK FOR PARTS OFF THE MOTOR.
The motor made 222whp/182wtq on a Dynapack in April 2009.
-Complete motor, transmission, Hasport mounts, harness, K-Pro -- $5,000
-Complete motor, transmission, Hasport mounts, harness, NO K-PRO -- $4,300
-Complete motor, transmission, harness -- $4,000
**NOTE: The motor is still in the car. So if you would like to hear it run/drive, you can.
Motor specs:
-2005 K20z1
-36k miles on the motor, around 15k miles on the rebuild
-Freshly built motor as of Feb. 2009
-86.5mm Wiseco 11.7:1 pistons
-Eagle rods
-ACL Race bearings
-New OEM Z1 oil pump
-Blueprint valvetrain
-Blueprint Stage 2 cams
-Supertech flat-faced valves w/ the 02-04 valve keepers
-Supertech valve seats
-RBC intake manifold
-RC 550cc injectors
-Golden Eagle fuel rail
-Hasport mounts
-OEM Z1 throttle body w/ Karcepts RBC adapter
-Hondata intake manifold gasket
-Hondata K-Pro w/ 05-06 adapting harness
-OEM ITR valve cover
-OEM '06+ Civic Si black coil cover
-EP3 idler pulley to remove powersteering
-NGK BKR7e spark plugs
Transmission:
-No "false" 3rd gear which is said to be common on the 05-06 6 speeds
-Have only ever used Acura's newest MT fluid, changed every 4k-5k miles with the engine oil
-OEM DC5-R LSD
-Competition Stage 4 6 puck clutch (sprung)
-'05 K20Z1 flywheel
I also have Drive Shaft Shop 2.9 EG/DC swap axles I could throw in for some extra $$ as well as the fuel components(lines, fittings, etc.)
Prices are pretty firm as I feel they are very fair prices for what you are getting. Feel free to PM me with any questions.
Pics:
Pictures show the motor with my old BDL 70mm throttle body, motor now has the stock Z1 throttle body.
Old Jan 3, 2010 | 07:10 PM
92EGK20's Avatar
Default Re: FS: Complete K20Z1 Swap|100% legit
Bump before bed.
Old Jan 4, 2010 | 12:50 PM
92EGK20's Avatar
hmmmm
Old Jan 4, 2010 | 02:22 PM
psi2high's Avatar
Bump for a strong running engine
Old Jan 4, 2010 | 07:56 PM
92EGK20's Avatar
Thanks buddy
Old Jan 8, 2010 | 03:59 PM
SLO EG1 SOL's Avatar
bump
bluxberryxhaze
Northeast (Sales)
Sep 22, 2009 07:29 PM
