euro accord
Honda Accord 2.2i, F22Z2
• Bore × Stroke: 85.0 × 95.0 mm
• Displacement: 2156 cc
• Valve Configuration: SOHC, 16 valves, VTEC
• Compression ratio: 9.3:1
• Max power: 150 hp (112 kW) @ 5500 rpm
• Max torque: 148 ft·lbf (200 Nm) @ 4500 rpm
It's pretty much an F22B1 with a touch higher compression.
From the pics it looks as though your exhaust header would be the same as the USDM 5th gen EX F22B1, if your looking for a cold air intake you would be looking for a USDM 90-93 4th gen Accord.
The engine is the same design as the USDM B1, but the engine bay configuration is more that of a 4th gen Accord than that of the 5th gen.
The upper intake plenum is a bit different, it looks taller in the center. But it looks to have the same ports.
Tonyneedshelp
Mar 7, 2015 07:12 AM
