Whats the best way to get dirt out of a manual transmission?
Its a prelude transmission i picked up for cheap. it had crap on it around the VSS and the guy before me removed the sensor, allowing the crap(dirt) to fall into the trans. not to mention all the dirt that got attracted to the oil in the output holes because it was kept on the ground... I want to flush it out somehow, can i remove the drain plug and spray a bunch of brake parts cleaner through the VSS hole?
yea, lots of crap inside... leaves, dirt, unknown... gears had rust, lots of water, final drive was nasty as ****. i used my old final drive and took the gearsets apart and cleaned, lubed and reassembled it all. put some new seals n **** too. it goes through all the gears so lets see what happens. i should be putting it in this weekend.
turbotime
18
Jan 29, 2007 08:01 PM
xhatchracerx
11
Jul 5, 2004 09:51 PM
RedHB..D15B
Apr 8, 2004 12:52 PM
