my car wont start please help
ok so my car wont start ive checked everything i can possibly think of first thing i thought is that the battery was dead because when i put the key to the on position none of my gauge cluster lights come on like the battery light and all that good stuff. so next i checked to see if i had a short somewhere but nothing. can some one please help me
Check your fuse box and fuses! If that does not work, check for a loose cable that is shorting on the body of the car. Found I had a cable shorting my battery out when I bought my 91 accord.
most likely a combination of weak battery and bad battery connection play with connection and jump or use a good battery sometimes acid from the battery contaminates the battery connections making poor contact and sometimes you can not see the acid. gl
braypunt
22
Sep 11, 2005 09:10 AM
ITRbroham
Nov 4, 2004 06:30 AM
