Suspension & Brakes Theory, alignment, spring rates....
using beaks bar with ASR
Old Jan 2, 2010 | 09:34 AM
2000EJ8's Avatar
Default using beaks bar with ASR
i just ordered my ASR bar and i want to use my beaks bar with it.....i know the beaks bar is useless combined with the ASR bar so i dont need anyone preaching about that
i remember seeing a while back that the bolts provided by ASR arent long enough to thread completely with the beaks and ASR together
does anyone know the bolt size and length for a 00 civic ex to run these together
Old Jan 2, 2010 | 01:49 PM
1.5Slowmatic's Avatar
Default Re: using beaks bar with ASR
take the bolts you have with the ASR and measure them. Then find out the width of the plate on the beaks bar and there ya go. Or you could just guesstimate and take the ones from the ASR and add about an inch and half to them.
Old Jan 3, 2010 | 11:53 AM
dstah's Avatar
Product #6323
Metric hex bolts, Metric standard bolts, Steel grade 8.8 fine thread, 10mm x 1.25 x 110mm
i ordered mine from boltdepot.com
Old Jan 20, 2010 | 09:53 AM
2000EJ8's Avatar
Originally Posted by dstah
Product #6323
will this work with this being the case........it seems that for some reason the bolt that goes through the ASR bar and LCA's is kind of sunk back into the bar... this is what mine looks like
notice how the bolts on the bottom picture one sit flush with the bar. will i still be able to mount my beaks bar using longer bolts with this being the case?
Old Mar 14, 2010 | 02:18 PM
real_slow_EM1's Avatar
anyone?
Old Jul 6, 2011 | 12:37 AM
1HGEJ2's Avatar
i push this thread and give all an answer
u can use the asr and beaks with nsx cross beam bolts
http://www.hondaoriginalparts.com/ho...block_03=21553
nr 17.
cost not much and its 110mm and 1,25 with m10
greets from germany
edit 7.8.2011
partsnumber
left asr bolt right nsx bolt
install
u need 110mm bolts
Teh Boss
Dec 22, 2012 08:29 PM
fergs96integra
Jul 21, 2010 07:07 PM
alec3369
Feb 9, 2008 09:21 AM
94gsr4dr
May 15, 2003 11:37 AM
