Oil pump for ZC motor
I bought a 1990 ZC motor from Japan out of a CRX. I am overhauling it to put in a 1991 CRX SI, I wanted to get a new oil pump, I have been basically buying 1989 Acura Integra parts as this motor wasn't used in the U.S. in Honda's. Melling offers a pump, M178, for the SOHC 1991, 1.6 motor and I was told this would work , but since they don't list a pump for a 1989 Acura 1.6, I am unsure, Advance Auto and Autozone don't list a pump for the Acura. Any advice would be greatly appreciated. Thanks in advance for any responses
Digging for more info......
So, I've searched a little and there are 2 sets of oil pump gears available for the usdm d16a6....maybe one is higher volume??? probably not.
What about a jdm dohc zc? Is that the same oil pump as edm? We can usually find a jdm dohc zc once in a while at the junkyards here near Los Angeles. Would a jdm dohc zc be the same higher volume pump as the edm model? I can't cross reference part numbers from jdm models, or I could check myself with the part numbers jlicrx has provided.
thanks.....
thanks.....
the zc sohc uses a usdm sohc Si D16A6 oil pump
the zc dohc uses the 1989 usdm Integra D16A1 oil pump
Does it bolt right up to a d16a6?
I'm not sure Deetz that we're talking about the same thing, or maybe you don't get what it is I am trying to get at.
Does jlicrx have a part number for the gasket for the higher volume oil pump which bolts up to the d16a6? thanks.
I gave you all of the info, what else do you want to know???
There is only one part number for each of those applications! You have to remember that both of those applications are very old, and it is common for part numbers to supercede to a newer part number right from Honda!
the 88-89 Integra D16A1 oil pump will not work on the DOHC ZC
there is no gasket for the oil pump
the USDM oil pump that fits is for the 88-91 D16A6 or 92-95 D16Z6
I sort of figured that, but thanks for confirming that for the other guys that read this thread...If it won't work on the DOHC ZC, it won't work on the D16a6 because the DOHC ZC oil pump bolts up to the D16a6......claaasssss pay attention!!!.....
From a Honda Factory online site (sorry no pics)
#6 15131-PM3-010 Rotor,Pump(Inner)(Sumitomo) no color
#6 15131-PM3-004 Rotor,Pump(Inner)(Yamada) no color
#7 15132-PE0-003 Rotor,Pump(Outer)(Sumitomo)no color
#7 15132-PE0-004 Rotor,Pump(Outer)(SYamada)no color
If I retained knowledge better, I would remember that the oil pump has no gasket, duh!
thanks again...jlicrx
Hopefully, I'm off to score a JDM DOHC ZC oil pump(17gpm) to install in one of my D16a6's (oil pump=11gpm)at 1/2 price day at the junkyard......woo hoo!!!
