block usable?
Old Jan 1, 2010 | 08:20 PM
bui1528's Avatar
Default block usable?
so i had bought a block from a guy for cheap.
well turns out part of the block is broken and idk if its still usable.
doesnt seem like its cracked anything but i dont want to run the risk of using it and having it crack like crazy on me. my friend told me that it is still usable as long as the chip isnt all the way through the block.
thoughts? im thinking of just getting a bare block and swapping everything over.
Old Jan 1, 2010 | 08:24 PM
Gunmetal_B20_Hatch's Avatar
Default Re: block usable?
I'd throw it in the garbage...
Old Jan 1, 2010 | 08:30 PM
thumper64's Avatar
D series, I'd junk it. B series, I'd get it welded up and fixed. I'm sure someone with a TIG machine could build that back up and make it like new.
Old Jan 1, 2010 | 08:31 PM
bui1528's Avatar
hmm would it be cheaper to get another bare block or just get it welded and fixed? idk how much that would cost me to get it welded.
Old Jan 1, 2010 | 08:32 PM
bui1528's Avatar
oh and its a gsr block
Old Jan 1, 2010 | 08:36 PM
Jdm John's Avatar
scrap it and get money then go buy another undamaged
Old Jan 1, 2010 | 08:37 PM
bui1528's Avatar
im thinking an undamaged block is the way to go. thanks to all.
Old Jan 1, 2010 | 08:38 PM
i-VTEC_do_you's Avatar
ya if you still have that piece any good welding shop should be able to securely weld that back on or build it up and re-thread, should be good as new.
good luck
Old Jan 1, 2010 | 08:40 PM
thumper64's Avatar
might be cheaper to get it fixed. I'd bring it to a couple shops and see what they'd charge.
Make sure to clean it up really well. Ask them to beef that area up. It seems to be a common place for motors to break. It will have to be rethreaded, I'd put Timeserts in, or Heli Coils. That would be better than putting bolts straight into aluminum.
bui1528's Avatar
hmm alright. well i dont have that piece would that be ok?
they would be able to just build it up from scrap right.
Old Jan 1, 2010 | 08:41 PM
thumper64's Avatar
How much did you buy the block for? If you scrap it, you won't get much... I brought a load in and got $30.
thumper64's Avatar
Yup, they can just build it up with weld. They'll just lay down bead after bead of weld.
Old Jan 1, 2010 | 08:42 PM
bui1528's Avatar
ok i might end up just do that.
and i bought the block for 200. full block and such.
Mad "b00sted" Max
Aug 12, 2003 09:05 AM
Soon_2b_evil
Aug 8, 2003 06:40 PM
toooslow
Jul 10, 2003 08:31 AM
