Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Swapping Struts and Stuck...
Old Jan 1, 2010 | 07:05 PM
griffithbuilt's Avatar
Default Swapping Struts and Stuck...
I went to swap my struts out in my '05 Civic Hybrid and when I unbolted the strut from the LCA on the passenger side, I obviously didn't have enough support of the hub and it pulled the inboard CV joint loose (but not entirely loose, turning the rotor still results in the entire shaft turning all the way to the transmission.
But now that I've got the strut back in I can't get the halfway engaged cv shaft ball/socket joint back engaged and can't get the hub inboard enough to bolt to the strut.
Any tips in realigning the geometry of the hub/LCA/CV shaft in order to get the CV re-engaged?
Jason
Old Jan 1, 2010 | 08:37 PM
slomofo's Avatar
GDD Member
Default Re: Swapping Struts and Stuck...
Remove the axle from the hub, grab the outer shaft with your hand and start rotating it like you'd rotate a steering wheel, then jiggle and rotate until it pops back in. Depending on how strong you are, you could even jiggle the knuckle around and move it side to side with the tie rod off to get it back in, I do it all the time.
Old Jan 1, 2010 | 09:50 PM
Yeah that was the route i ended up going (still am). I got the 32mm nut off the outboard side of the axle shaft, but can't get it out of the knuckle. Only thing holding the knuckle on at this point are the wheel speed sensor wire, ball joint, brake line and a rope I used to tie the strut bosses on the knuckle up to the strut top mount points.
Any tips on how to get the shaft out of the knuckle at this point? It's got about an inch or two to go. And I'm having a bitch of a time trying to get the ball joint off without the top of the knuckle being attached to a strut tube.
Lame. Oh well, tomorrow's another day. Any advice would be helpful.
Jason
Old Jan 1, 2010 | 11:05 PM
slomofo's Avatar
GDD Member
Use a pickle fork and a hammer on the lower ball joint if you can't get it off. Use a pry bar to bend the lower control arm down enough to clear the ball joint.
Old Jan 2, 2010 | 10:23 AM
Yeah I was hoping to not have to use the pickle fork for fear of damaging the ball joint boot...but you're right - that's looking like the only solution.
Jason
Old Jan 2, 2010 | 10:54 AM
portaman03's Avatar
whack the shart out of it with a 5 lb sledge. worked wonders for me.
Old Jan 2, 2010 | 12:44 PM
Is there a circlip inside that inner CV that could have popped off, and if so, do I need to remove the entire shaft all the way back to the transaxle in order to disassemble and replace the circlip?
Jason
Old Jan 2, 2010 | 03:27 PM
slomofo's Avatar
GDD Member
If you can't get it back in, take the axle out all the way and do the jiggle/rotate method on a bench. It'll go back in, they always do.
Old Jan 3, 2010 | 06:52 PM
We left it in, just pulled the boot, got it back in and then reclipped the boot. Worked fine.
RA041024
Honda CR-V & Element
Oct 23, 2018 07:06 AM
B_Swapped93
Dec 21, 2013 10:48 AM
lowtegsr
Feb 1, 2008 07:18 AM
ludenoob99
Aug 14, 2007 05:13 PM
07734
Dec 1, 2004 06:51 PM
