Liquid Wrench vs WD-40
Old Jan 1, 2010 | 05:21 PM
dleccord's Avatar
Default Liquid Wrench vs WD-40
which is better if i spray it on my crank bolt everyday for one week straight.
trying to do my timing belt.
Old Jan 1, 2010 | 05:38 PM
CuteAccord's Avatar
Default Re: Liquid Wrench vs WD-40
WD-40 has never failed me, only thing that bothers me is the smell. Is that being too girly?
Old Jan 1, 2010 | 06:17 PM
dleccord's Avatar
a bit.
Old Jan 1, 2010 | 06:50 PM
Robotoyaki's Avatar
The April/May 2007 edition of Machinist's Workshop did a test of penetrating oils where they measured the force required to loosen rusty test devices. Buy the issue if you want to see how they did the test. The results reported were interesting. The lower the number of pounds the better. Mighty interesting results for simple acetone and tranny fluid!
Penetrating oil . Average load .. Price per fluid ounce
None ................. 516 pounds .
WD-40 .............. 238 pounds .. $0.25
PB Blaster ......... 214 pounds .. $0.35
Liquid Wrench ... 127 pounds .. $0.21
Kano Kroil ........ 106 pounds .. $0.75
ATF-Acetone mix.. 53 pounds .. $0.10
The ATF-Acetone mix was a 50/50 mix (1 to 1 ratio)."
Old Jan 1, 2010 | 07:12 PM
dleccord's Avatar
why is it that the lower number the better?
Old Jan 1, 2010 | 09:48 PM
Robotoyaki's Avatar
The lower the number, the less the torque required to remove a rusted fastener. Liquid Wrench is almost twice as effective as WD-40,
and ATF-Acetone is almost 5 times as effective as WD-40.
Old Jan 1, 2010 | 10:38 PM
philiam's Avatar
WD stands for water displacement. It's not meant to be used for the myriad of things people us it for. Liquid Wrench is better suited to loosening things.
Old Jan 1, 2010 | 11:00 PM
dleccord's Avatar
where can i get this atf acetone? so would it drop the 180 ft lbs down to like 50 ft lbs at the crank bolt?
Old Jan 1, 2010 | 11:19 PM
19Accord97's Avatar
Liquid Wrench.
Even better yet is a product called Metal Creep or something like that.
Old Jan 2, 2010 | 10:21 AM
Robotoyaki's Avatar
Acetone is available at any paint or hardware store. ATF= automatic transmission fluid. Mix the two in equal volumes.
Old Jan 2, 2010 | 10:27 AM
slomofo's Avatar
GDD Member
I just use a few drops of regular motor oil, then come back in about 20 minutes. Sometimes I'll use PB Blaster, but I can usually get stuff off with air tools, motor oil, or with heat.
Robotoyaki's Avatar
It's mostly mineral spirits (paint thinner) and mineral oil (baby oil) with some fragrance added.
Old Jan 3, 2010 | 05:47 AM
plugger's Avatar
If it's choice between LW and WD-40, LW is a better penetrating oil, no question.
I haven't tried the ATF/Acetone formula, but one thing to consider is that it may be less convenient to use than a product in handy pressurised spray can. Just something to consider.
Old Jan 3, 2010 | 01:24 PM
pimpz142's Avatar
^ x2
Bottle
Dec 23, 2009 08:50 PM
Bulli Kid
Honda Civic (2006 - 2015)
Jun 17, 2007 07:28 PM
Catch 22
106
Dec 20, 2005 09:39 AM
Dan GSR
17
Mar 6, 2003 12:59 PM
