Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Blower fan doesnt start until car warms up?
Old Jan 1, 2010 | 04:52 PM
diamondhonda03's Avatar
New User
Default Blower fan doesnt start until car warms up?
My blower fan doesn't work until the car warms up a little bit. Same thing goes for the defrost. Once I do get going it works fine, but what causes this??
One other thing I noticed is that when I rev the engine on idle the blower fan output increases as well. Not sure if the two are connected but thought I'd mention it.
I've got a 2003 Honda Civic with 57K miles on it
Old Jan 1, 2010 | 08:44 PM
slomofo's Avatar
GDD Member
Default Re: Blower fan doesnt start until car warms up?
Are your battery terminals dirty?
Old Jan 2, 2010 | 08:58 AM
New User
Its a new battery, but I suspect the clamps need to get cleaned. Whats the best way to do so? Why might this be causing the blower/defroster problem?
Thanks for the response, I really appreciate it.
Old Jan 2, 2010 | 07:37 PM
slomofo's Avatar
GDD Member
Dirty cables could be the reason your heater blows stronger when you rev the engine. I have no idea why it doesn't blow when the car is cold.
Old Jan 4, 2010 | 04:51 PM
New User
I cleaned the clamps and post on the battery. Glad I did because there was a lot of garbage on them, especially the positive clamp. I'm not sure if it made a difference.
I did check and I'm able to run it on all settings so I don't think its the resistor, and I was also able to run it without the car being on. Not sure if I was supposed to do that but it worked.
Any other ideas? Is this symptomatic of a bigger problem?
rnjerseyhonda
May 11, 2011 02:42 PM
hastingsr
Sep 9, 2009 03:26 PM
londonsupra
Feb 13, 2007 08:34 AM
bigrballerz
Oct 3, 2006 11:48 AM
oldchicagoguy
Oct 21, 2004 03:47 PM
