b20 reliability
Old Jan 1, 2010 | 04:47 PM
thegatekeeper14's Avatar
Default b20 reliability
im just wondering how reliable the b20 block is.
Old Jan 1, 2010 | 09:13 PM
Targa250R's Avatar
be professional
Default Re: b20 reliability
The zillions of perfectly-running '97-01 CR-Vs out there would lead one to believe that it is pretty "reliable."
There you go, a vague answer for your vague question.
Old Jan 1, 2010 | 10:32 PM
ok well i have a fully sleeved b20 with AEBS sleeves. and a type r head. built for high boost.
now am i gonna have oiling issues with this block or not?
Old Jan 4, 2010 | 10:09 AM
supra-n-civic's Avatar
ok for stock or light mod with out sleeves. i have a stock b20b bottom end ( i got it unassebled and reassembled it) i used acl bearings and arp head studs and some nippon piston rings and integra type r oil pump in my bottom end. as for the head its all stock but a set of crower 403 cams (will be getting springs and retainers before my final tune) but its fine. they will run fine all day long if kept under 7000 rpms. and with out boost. alot of people have had problems with boost without having sleeved them. but generally its all in the tune.
Old Jan 4, 2010 | 04:33 PM
94_DC's Avatar
ROD BOLTS!
Old Jan 4, 2010 | 05:13 PM
thundernoodle's Avatar
see the stock b20 sleeve thread in the all motor section
Old Jan 5, 2010 | 08:51 PM
well mines sleeved with type r oil pump revining to 8500 type r hear and eagle rods
Old Jan 8, 2010 | 10:36 AM
IanB's Avatar
Well the weak points are the sleeves and the rod bolts, both of which you have changed, so are you asking about the actual block casting, or what? Better questions yield better answers.
Old Jan 8, 2010 | 08:02 PM
im wondering if there is an oiling issue with the blocks?
Old Jun 18, 2024 | 06:09 AM
Krizo's Avatar
In general, the engine is very good, with proper maintenance goes for a long time, the resource b20b about 300 thousand kilometers and more. If the motor came and requires overhaul, it is easier and cheaper to buy a contract engine B20B, the price does not bite. Source: https://www.motorxpertisehub.com/hon...-2-0-l-engine/
greydelta38
28
Mar 31, 2014 08:13 PM
vtak2nr
Jun 22, 2011 06:49 AM
urtz
21
Aug 28, 2008 06:23 AM
d16z6ef
Dec 12, 2007 12:18 PM
EK SQUAD 425
Sep 18, 2007 06:48 AM
