v-afc
Old Sep 3, 2002 | 06:35 PM
89JDMcrx's Avatar
Default v-afc
I was wondering if installing a V-AFC is easy to install because alot of my friends are saying take it to a professional, but i don't want to cause i like to install all the thing i get for my car..its the only way to learn...so is it easy to install?
Old Sep 3, 2002 | 06:40 PM
NVMYSi's Avatar
Default Re: v-afc (97exracer)
Yes, It is easy to install. Read through the instruction book first and follow it step by step and you will be fine. I just installed mine last week with no problem, took about 2-3 hours (and I work slow). Just remember your not putting a man on the moon here, your just installing a VAFC....
If you have problems IM me and I'll try to help...
Old Sep 3, 2002 | 06:51 PM
CzanSOHC's Avatar
Default Re: v-afc (NVMYSi)
it's really easy man...took me about a 1/2 hours....becarful becuase all my directions were all in Jappensee....but just go to apexi website if that happens...what are you installing it on? Just make sure you spice the ground wire just like they show you..and do all you sensor stuff before yo start the car...easy stuff
Old Sep 3, 2002 | 06:53 PM
3700 Vtec's Avatar
If your comfortable with your skills, then go for it. I had mine done by a professional because there isn't a clear diagram for the F23's and even having mine done by a professional there were complications. After installing go to the sensor check because one of my friends had problems with the wiring to his throtle position sensor, which will screw you car up, it should be around 4.5.
Old Sep 3, 2002 | 06:55 PM
89JDMcrx's Avatar
thanks im going to try it
Old Sep 3, 2002 | 07:04 PM
89JDMcrx's Avatar
well i know how to splice wires i've done a billion times especially installing gauges.
Old Sep 3, 2002 | 07:38 PM
KoRE's Avatar
Default Re: v-afc
don't just electrical tape the wires use solder ...
Old Sep 3, 2002 | 07:43 PM
dirtySOHC's's Avatar
Default Re: v-afc (KoRE)
summit posi lock connectors are good too. the best thing have used when conecting wires
Old Sep 3, 2002 | 07:56 PM
89JDMcrx's Avatar
what do i have to solder?
Old Sep 3, 2002 | 08:09 PM
redline201's Avatar
(97exracer) what other mods do you have for your car and what motor
i was thinking of getting a vafc and some cam gears for my b16a but i only have I/H/E and a high flow cat
not sure if a vafc is worth it for me
lemme know your setup
Old Sep 3, 2002 | 08:17 PM
89JDMcrx's Avatar
this is what i have: Cold air intake, full catback exhaust, Unorthadox pulleys, fuel regulator, igntion wires, headers.
Old Sep 3, 2002 | 08:21 PM
dogpile5's Avatar
25 Year Member
mind if i quote you on that one
Old Sep 3, 2002 | 08:23 PM
CzanSOHC's Avatar
Default Re: v-afc (dogpile5)
Apexi recommends you soder...but...not worth the time in my opinion...just use all the connectors they give you and tape eveything up...your good to go.
Old Sep 4, 2002 | 08:21 AM
NVMYSi's Avatar
Ha, go ahead..
Old Sep 4, 2002 | 08:33 AM
VTC_CiViC's Avatar
Default Re: v-afc (CzanSOHC)
Well personally, I soldered everything when I installed an AFC in my car and in a friend's... much more reliable connection, and only took like 2hrs.
all_out_jdm
Mar 19, 2005 01:07 AM
Catera
Apr 5, 2004 09:45 AM
genetsang
Mar 14, 2003 11:02 AM
