Car won't start....
Old Jan 1, 2010 | 03:40 PM
slostdhatch's Avatar
Icon2 Car won't start....
First post, and I feel like an idiot...
I have a 1991 Civic STD hatch with the stock dpfi system and now it wont start
Basically, I drove my car to work fine and when I went to go home it wouldn't start. My first thought was obviously the battery so I tried to pop the clutch and it still refused to start.
Wasn't the battery, the car turns over fine.
Got the car home and checked EVERYTHING I can think of.
The ECU is not throwing any codes, The spark plugs are firing, I replaced the entire distributor thinking it may have been the ignition coil rotor or some other part.
When I turn the key on to the second position I can hear the fuel pump, and I even have pretty good fuel pressure.
The car just refuses to fire.
I replaced the old 4 speed transmission with a 5 speed Si transmission some months ago and it ran fine afterword. I am at a complete loss as to what the problem could be.
Old Jan 1, 2010 | 03:52 PM
elf469's Avatar
Default Re: Car won't start....
It's turning over, just not starting? or just not doing anything at all?
Old Jan 1, 2010 | 04:36 PM
BiG ChOr!Zo's Avatar
maybe the distributor rotor button fell off or you didn't tighten it correct...!!!
Old Jan 1, 2010 | 04:38 PM
elf469's Avatar
LOL. that happened to me a few months ago!
Old Jan 1, 2010 | 05:25 PM
Its turning over just not starting.
The rotor is on just fine, haha.
Old Jan 2, 2010 | 06:58 PM
Do you think the problem could be a faulty main injector?
BolivianFuego
Apr 9, 2011 09:34 AM
Zion-I
Jan 24, 2007 07:34 AM
phathatch
May 13, 2006 09:08 AM
c-y-nickel
Mar 16, 2004 04:24 PM
