Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
car bogs out of no where
Old Jan 1, 2010 | 03:32 PM
komat's Avatar
Default car bogs out of no where
ever since i got this motor, every once in a while i would get bogging/stall problems. when i would step on the gas all you can hear is the intake sucking in air but the engine doesnt do anything. if i pull it out of gear the rpm will just drop instantly to 0/stall out.
the only way to get the car started back up is turning the key off then back on. the car wont even run again if i pop it back in gear while the car is still rolling down a hill or still have enough speed to do a running start unless i turn the key off/on.
has anyone had this problem before? it only started doing it with this motor. i had 4 other motors on this car before with no problem. i thought it could be the map sensor but it doesnt make sense that i have to turn the key off and on to get it running again
Old Jan 1, 2010 | 03:59 PM
clemsonhatch's Avatar
Default Re: car blogs out of no where
Do you own Kitt? Can you post a link to the blog?
Old Jan 1, 2010 | 05:01 PM
i-VTEC_DOHC's Avatar
Default Re: car bogs out of no where
single stick?
Old Jan 3, 2010 | 02:54 AM
Kidnkorner's Avatar
sound like you posted in the wrong forum. Your crank angle sensor in your distributor is bad. distributorking.com is y0! friend.
Old Jan 3, 2010 | 11:05 AM
komat's Avatar
oh ****
i thought i clicked on the 92-00
my bad
knettles5
21
Sep 4, 2012 05:41 PM
Hoppa
19
Apr 18, 2005 07:57 AM
SivikHatch
Aug 12, 2004 12:05 AM
